Salta al contenuto principale
The Dell VRC-100R can be identified by its model number: 536-BBBS. It is a first-generation Bluetooth virtual reality controller that was released in October 2017.
Fixing the trigger on the WMR Controller?
The trigger on my right controller is stuck “pushing in” when I am in VR. I have tried to disasemble the controller to see if there is anything wrong with it, looks like it’s missing something. What could it be missing? I don’t want to disassemble my left controller needlessly to see if it’s missing something.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Ok…well apparently ifixit thinks my answer is spam. I’ll try one last time:
I think I may have the same issue, and I fixed it. I followed the ifixit guide for doing a touchpad replacement (apparently if I link to that tutorial, this post gets marked as spam, so you’ll have to find it yourself), through step 7, removing the back panel, which contains the trigger. In my case, the small metal rod that holds the trigger in place and allows it to rotate had slipped out of the hole on one side. I wiggled it back in place, and after putting everything back together it worked. It looks like this rod could easily slip out of place. Not sure if this is the same issue for you, but I hope it’s helpful. Best of luck.
Punteggio 0
Parti & Attrezzi Popolari
Aggiungi la tua risposta
NO PE sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 804
