Salta al contenuto principale
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
Why does Kernel_Task keep on throttling my Macs CPU?
When using iMac (Late 2013 27" which has been fitted with an SSD) Kernel _Task throttles CPU. Instead of the CPU running at 3.2GHz, it will run no faster than 0.8GHz and fans run at 3000+rpm. Have checked all temperature sensors and all work fine. The mac is also not overheating. When running Apple hardware diagnostics, it tells me there may be a problem with the system management controller (SMC). Resetting the SMC temporarily fixes the kernel_task problem but it always returns. Any ideas what may be causing this issue?
Questa è una buona domanda?
Punteggio 1
3 Commenti:
What is the SSD (make & model) and which port did you install it.
da
I installed Samsung 830 series 512gb ssd and it was installed in the sata port
da
Your SSD specs Samsung 830 series
da
Aggiungi un commento
1 Risposta
Why are you using such an old SSD? This is what you should be using Samsung 860 EVO and you need this in-line sensor OWC In-line Digital Thermal Sensor for Hard Drive Upgrade for 27" iMacs 2012 and Later
Punteggio 0
Parti e strumenti correlati
Acquista tutti
Aggiungi la tua risposta
Liam Boyle sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 205
