Salta al contenuto principale
Il Galaxy S7 Edge è la variante schermo curvo del telefono top del 2016 di Samsung, il Galaxy S7. Annunciato a febbraio 2016 e lanciato l'11 marzo. Modello SM-G935.
Charges for a Moment Then Stops
Hey fixers!
so i lost my phone when i was out drinking and fortunately it got found. since i have it back, when i charge it it shows the charging logo on the screen but after a few seconds the screen gets a bit brighter and then stops. so it doesnt go to the screen where you see the battery with the percentage in there or the led light which is usually red when it charges in the top right corner. (the phone was out of battery life since having)
What i have tried (with no succes):
-battery replacement
-cleaning charging port
-look for water damage
is this a charging port problem? i cant try wireless because i dont have it.
or maybe a motherboard or display problem?
Thanks in advance and cheers!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
What happens when you try to hold the power button for about 10 seconds while it's plugged into the charger?
Punteggio 1
1 Commento:
it seems like that starts the charging again but in the same exact way, (i holded power button after the screen stops showing charging while keeping it in charger)
da
Parti e strumenti correlati
Acquista tutti
Aggiungi la tua risposta
Bas Velden sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,687
