Salta al contenuto principale
500 series DSLR camera developed by Nikon. Released in February, 2011.
20 Domande Visualizza tutte
doesn't fully shut off (coolpix b500)
hi,
so my Coolpix b500 (they didn't have that in option) isn't shutting off properly, when i shut it off the green light still is on and the battery's die soo fast! (I use lithium) I have check every setting and have looked on the internet but I cant figure out how to fix it!
please help!!
Questa è una buona domanda?
Punteggio 3
1 Commento
Where is the solution to this problem?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I have this issue too. What I do is turn it off, put the lens cap on then turn it on. A message will come on the screen to turn it off then on again. Once I turn it off this time the light goes out. Hope this helps
Punteggio 2
4 Commenti:
I have done this before but wasn't sure if it was okay for camera and if it fully shut off, thanks!
da
Thanks Karen. I was having the same problem but your solution fixed it. Thanks again.
da
Well done…troubled me for ages…works! Thank you..
da
This method seems stupid to me. To use an error action to make the light go out. What does Nikon say to do to get the green light to go out when you shut the camera off. That should do it on the B500.
da
Aggiungi la tua risposta
heusscarolyn sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,794
