Salta al contenuto principale
The LN46A530 has a 46" display, combined with SRS TruSurround XT. The PC input allows this display to double as a 46" computer monitor
Why distorted sound when using HD Antenna on local channels
Why is the sound on my tv distorted using a HD Antenna on local channels, but okay when using Netflix
Questa è una buona domanda?
Punteggio 0
1 Commento:
@andersongraddy is the HD antenna connected via Coax or how? Netflix is received how? HDMI tabletop box? Network? What have you tried? Is the sound okay with all other input sources just bad with the HD antenna? Your TV is a Samsung LN46A530P1FXZA ?
da
Aggiungi un commento
1 Risposta
I would have expected that the video would be less than perfect before the sound since the video requires more information for processing than the audio. That being said, this sounds like a signal quality problem and not a problem with the TV itself.
Dan
Punteggio 0
Aggiungi la tua risposta
Christine sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 367
