Salta al contenuto principale
Nel 2012, Sony annunciò che la società avrebbe rilasciato una nuova versione della sua console PlayStation 3 del 2006. La nuova console fu chiamata PlayStation 3 Super Slim ed è identificata dal numero di modello CECH-4000. La PlayStation 3 Super Slim (CECH400x) è la terza versione della console per videogiochi PS3 prodotta da Sony Computer Entertainment. Fu lanciata sul mercato il 25 Ottobre 2012.
disc not reading and spins then stops..
Hello, I am needing help on fixing on my ps3 super slim. I'm trying to play a game on it and it spins then stops about three times, and it won't show the disc icon with the name of the game. Can anyone help me with this situation??
Questa è una buona domanda?
Punteggio 2
4 Commenti
Hi @therealrjrios try with another disc type, e.g. dvd video.
Does it works ?
da
Hello @salmonjapan , yes every single game I had did not work. as I did mention in my question, it won't show the disc icon with the name of the game.
da
Mine plays cd’s and dvd’s but doesn’t play or ID any of the Game disc’s?. It’s like it starts to spin up and actually Read the Game disc and then fails to relay or read the
data ?
da
Forgot to mention that i did install a brand new blueray dvd drive.
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
When a disc is loaded, the system attempts to read the TOC (table of contents) of the disc. This is the spinning that you hear. If the TOC is not readable, the spinning stops. This will be attempted 3 times (sometimes more). In your case, the disc is not readable. This can be as simple as dirt on the DVD lens or a failure of the laser itself. If you can gain access to the drive, try cleaning the lens (carefully) using a cotton swab and alcohol. This may resolve the problem. If not, then replace the drive.
You can get the laser assembly for around $15 and the entire drive for around $40.
Dan
Punteggio 1
1 Commento:
the game im getting issues with is Driver San Francisco where everything is fine until i try and load the mission where i prove to jones that i can "shift" as i get to the loading screen where within 90 seconds the disc will completley stop spinning
da
Parti e strumenti popolari
Acquista tutti
I replaced the entire set up. It read the disk finem then when I came back to it, it stopped. It just spins and clicks.
Punteggio 0
1 Commento:
I find a well deserved threat or slight WACK with a fist or small footed person helped. Other option is to place it firmly against a wall from 6 foot away. Then put it in a bin. Sorted
da
Ok so I had this same problem but I was able to fix it ok,so I know you might hear/see this a lot on the Internet as a solution "cleaning or replacing the laser",now for the PS3 super slim you are able to clean the laser without having to dismantle the entire thing just open up where the disc goes and you'll see two little glass circles, get a cotton tipped applicators non-sterile aka qtip and just gently rub it against those two glass circles and around it and that should fix it,it did for me but also make sure that your disc has no scratches and is also clean i hope this helps.
Punteggio 0
Aggiungi la tua risposta
RJ Rios sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 81
Tutti i Tempi: 17,052
