Salta al contenuto principale
A1708 / EMC 2978 — Lanciato nell'ottobre 2016, questo MacBook Pro entry-level conserva i tradizionali tasti funzione (invece della Touch Bar OLED). La versione function key adotta l'Intel Core i5 e 2 porte Thunderbolt.
2107 MacBook Pro Function keys SSD swap into a 2016 Function keys mode
Anyone know if the 2017's SSD will work in the 2016?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
If you have a mid 2017 function keys model and a late 2016 function keys model the SSD should be interchangeable.
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) SSD
Immagine Replacement or Upgrade Solid-State Drive/ Unformatted Drive/ PCIe SSD/
Prodotto
$249.99
Punteggio 1
3 Commenti:
@mayer I did some searching and I came to this conclusion.
da
@ajcooke01 As you may be aware, I try to take some time everyday to work on old questions.
da
@mayer You are one of the good ones among us. I try and do the same, but most of the time the questions that go unanswered are the ones that are not understandable, hard to answer or just simply just not answerable at all.
da
You’ll need to wait until IFIXIT has had a chance to open one up to see what Apple has setup.
Punteggio 0
2 Commenti:
@danj any update?
da
Per IFIXIT teardown it's the same! SSD
da
Aggiungi la tua risposta
James Liu sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 310
