Salta al contenuto principale
Plastic seating devices for patios, poolsides and bachelor pads.
How to fix a fixed stripped Table Leg?
Hi All,
How can I fix a stripped Table Leg? The leg has built metal treads, leg is stripped and no longer stays in.
Questa è una buona domanda?
Punteggio 0
1 Commento
I also had such a problem, I never solved it. The table is in the garage
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Take any thread(the kind you sew clothes with) and wrap it around the stripped side of nut counter clock wise. Go around the nut with thread (if thread Is pretty thin) counterclockwise at least 4 times and than screw it in to other piece.
Punteggio 1
Preparati per le riparazioni future
Aggiungi la tua risposta
Danny Chiu sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 730
