Salta al contenuto principale
Repair guides and support for the random-access memory used in computers.
What does the missing chip do
== Hello i have a Samsung 1x 8GB DDR4-2133p that lost a chip==
the problem is that under shipping one of the small chips on the backside for it got damaged, and i wound if it could be fixed or if it's just trash now.
i have add 2 pic of the ram in questing, with a working par about the one that lost its chip in the first pic
Link to the Ram from samsung.
https://www.samsung.com/semiconductor/dr...
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
LoD-RoG  those are resistors and, unless you can measure the one next to it, pretty impossible to replace.
Punteggio 2
1 Commento:
Your right! Its a dual resistor. It is 4-pin resistor array, two resistors, value 15 ohms each
da
Preparati per le riparazioni future
Risposta Più Utile
Sorry to say getting one of these small inductor coils will be difficult, likely not salvageable.
You said it came off during shipping. What this loosely packed and mailed? if that is the case I would see if shipper has insurance or if the seller will accept it as a return,
Punteggio 3
Aggiungi la tua risposta
LoD-RoG sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 563
