Salta al contenuto principale
Personal computer produced by Toshiba in early 2014 . The Satellite S55T-B5335 has a 15.6" touchscreen display, Intel Core i5 processor, and 1 TB hard drive.
11 Domande Visualizza tutte
Do I need a new digitizer or LCD?
I have a laptop with a cracked screen, and the touch screen works until a certain point of the screen (the marked red area of the picture). Does this mean I need to get a new digitizer? or is this just an issue with the LCD.
I also have a horizontal green line that goes across my screen, is this the LCD?
Thanks in advance!
(also my laptop is a satellite s55t-b5233, but I wasn't able to pick that model from the device list)
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Well, i'm guessing the lcd and digitizer are sepperate since its a touchscreen laptop, so i'm guessing you are fine with just replacing the ' touchscreen part'.
Punteggio 1
2 Commenti:
Thanks for the replies! I will try switching out the digitizer and hopefully that will fix it. :)
da
Good luck replacing it !
da
The image itself does not present any significant damage if any at all, so you should be fine just replacing the digitizer.
From the (veryveryvery quick) research I've done, the LCD and Digitizer are separate and not glued together as in some models, so the digitizer alone can be replaced, it seems.
There are quite a few tutorials on YouTube and Google on how to replace it.
Let us know of any other questions or issues that might come up.
Punteggio 1
2 Commenti:
That's helpful to know. Google has been and will continue to be my friend.
da
Best of luck, Billy, let us know how it turns out and if there's anything else I can help you with!
da
Aggiungi la tua risposta
billyboy062002 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 271
