Salta al contenuto principale
Dell XPS 13". The smallest 13" laptop on the planet that also has the world's first virtually border-less InfinityEdge display, as claimed by Dell. Released in 2012.
Keyboard with water damage
My keyboard got wet and now a few keys are not working. Is the keyboard for the XPS replaceable?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
@gts112009 yes it is but a bit of a PITA. Download the maintenance manual from here Page 77 will show you how to do it. 30 Philips screws keep the keyboard attached to the palm-rest assembly (basically your top case)
Punteggio 1
Before you replace the keyboard, check the Keyboard Control Board. This is just under the battery, removal is described in the manual.
I had water damage, replaced the keyboard which was a PITA, to then find out that is was the contacts on one of the sockets on the Keyboard Control Board that had failed.
Hope the helps someone!
Punteggio 0
Aggiungi la tua risposta
Karl Ganshirt sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,068
