Salta al contenuto principale
The third generation of the Samsung Galaxy tablet with a 7-in. screen announced on June 24, 2013. Repair of this device requires screwdrivers and prying tools. The device is available in white or gold brown with 8, 16, or 32 GB of storage, and includes a microSD slot that can hold up to an additional 64 GB of memory.
Battery indicator is incorrect
Battery indicator is incorrect, shows 1% for ages but will work for ages after this but screen is hard to see as automatically goes to dark. Probably at about 50 % but shows 1% . Don't want to do a factory reset any other suggestions
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Soluzione Prescelta
thanks i will try this
Punteggio 0
Preparati per le riparazioni future
Acquista tutti
Risposta Più Utile
The battery probably needs to be replaced, if that doesn't help then it's a board level issue that I don't think is worth repairing.
Battery is fairly cheap to replace.
Samsung Galaxy Tab 3 7.0 Battery Replacement
The screen flickering occurs when there is a critically low amount of charge on the battery so the battery is actually close to flat.
Immagine Replace a dead or damaged battery for your Galaxy Tab 3 7.0 Wi-Fi tablet with this part and fix issues with battery life. This is a used, OEM battery.
Prodotto
$17.99
Punteggio 3
Aggiungi la tua risposta
Michelle Green sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,377
