Salta al contenuto principale
The HP Officejet Pro 6835 is an ink printer that has a built in scanner and copier. Pages can be printed directly via USB connection or over WiFi. The printer can be identified by its model number: J2D37A
Help bypass Code Ox6100004a
I have a code on my printer that reads paper jam or repair/replace ink. I replaced all ink, checked all paper access points. No jam and full of ink. Code still remains. Any info would be much appreciated.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Perhaps the following post will help:
"There is a problem with the printer or ink system"
Seems to be exactly the same problem you are seeing. Be sure to read all of the comments/replies.
Punteggio 0
Parti & Attrezzi Popolari
Aggiungi la tua risposta
butlercanecorso sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 958
