Salta al contenuto principale
A standard cordless compact DeWalt 18V drill with a high performance motor that delivers 380 watts. Equipped with easy to hold design that allows you to work in difficult spaces.
Why is my trigger stuck in forward or reverse
Trigger is stuck on unless the battery is removed or the directional selector is between gears. How do i fix it or where can i buy the parts.
Questa è una buona domanda?
Punteggio 0
1 Commento
It is a dewalt dw929
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Planemech -
I occasionally have that issue with one of my drills. I spray WD40 into and around the trigger and work it back and forth vigorously. Let the excess drain out. Usually that works. Electrical contacts are well above trigger housing area, so no problem there.
Good luck,
Russ
Punteggio 0
Preparati per le riparazioni future
Aggiungi la tua risposta
planemech_2 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 25
Tutti i Tempi: 3,899
