Salta al contenuto principale
Il telefono allora al top della gamma Samsung, il Galaxy S8, è stato lanciato nell'aprile 2017.
Phone is echoing not software issue
Hello,
My galaxy s8 is echoing for people who are talking to me on it. They can hear themselves on their phone. I have tried all the software fixes I have found available, and I am pretty sure it is a hardware issue. I was just curious if I should replace the earpiece speaker or the i/o daughter board.
Questa è una buona domanda?
Punteggio 2
2 Commenti:
Hi Stephen, just wondering whether you’ve had this issue resolved? Am facing the same problem myself, but it only started happening after a daughter board charging port replacement, so I’m not sure whether replacing it again will resolve it.
da
Hi guys, I have the same problem after charging port replacement.. Did anybody resolve this issue?
da
Aggiungi un commento
2 Risposte
Try Reset network settings or turn off noise reduction in call settings
Punteggio 0
2 Commenti:
Hi Steve, thanks a lot for your fast reply.
Unfortunately, in Android Pie is no option like “noise reduction" in call setting and what do you mean about a “network reset”? There is also no option like this..
da
Via settings -reset -reset network settings
da
The answer was replacing the i/o daughter board
Punteggio 0
Aggiungi la tua risposta
Stephen Arends sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 315
