Salta al contenuto principale
Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
Where is the GPS in CDMA iPad?
The Broadcom BCM4751 is clearly identified in the iPad 2 GSM breakdown. What chip provides GPS in the CDMA iPad 2?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Risposta Più Utile
from here The key differences to note are that the CDMA model has an additional antenna compared to the GSM variety and it also uses a Qualcomm Gobi dual-mode radio with integrated GPS that actually supports both CDMA and GSM, but the GSM compatibility is unused by the iPad. And this The GSM iPad 2′s 3G radio has an Intel 36My1EF with 128MB of Numonyx NOR flash and Elpida Mobile DDR SDRAM, Infineon 337Se833 Baseband Processor, Skyworks TriQuint Transmit Modules, and Infineon 338S0626 GSM/W-CDMA Transceiver. It also includes a Broadcom BCM4751 Integrated Monolithic GPS Receiver, which is an update from the BCM4750 found in the GSM iPhone 4. from here http://wi-fi.me/2011/03/30/comparison-of... So,yes cityzen is right it is integrated.
Punteggio 2
2 Commenti:
+ really nice work
da
Thanks - very helpful.
da
Apparently, the Qualcomm MDM6600 performs that function. At least, that is what everything thinks (as shown by a web search).
Punteggio 0
Aggiungi la tua risposta
John OShaughnessy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,400
