Salta al contenuto principale
HP Photosmart Premium Wireless All-in-one Color Inkjet Printer/Fax/Copier/Scanner introduced 2009.
Why is my printer not printing from the wireless computer commands
why is my C309a HP Photosmart Premium printer is not printing from the wireless computer command?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Could be several things. First, I would verify that the computer and printer are connected to the same wireless network, then, print a configuration page directly from the printer panel. Verify the IP address is the same as the one in your printer icon in the computer printing settings (on computer). If different, add the new ip address to the printer icon, print test page. You have to so this again, if you don't make you ip on the printer static.
Punteggio 0
Preparati per le riparazioni future
Using the onboard display, go to Wireless. Somewhere you should be able to print a Diagnostics page. This should tell you if your Radio (more commonly known as Wi-Fi) is turned on and is working. As of April 2020, it said that my Radio was not working and I found out many of the cards were defective.
Punteggio 0
Aggiungi la tua risposta
joch1203 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 394
