Salta al contenuto principale
Won’t hold charge
If my iPod doesn’t hold charge is it the battery or the logic board
Questa è una buona domanda?
Punteggio 0
1 Commento:
Are you syncing to a Mac or PC?
da
Aggiungi un commento
2 Risposte
Battery. If it boots with a 10W adapter, then the battery needs replacing. Replacing your battery requires a solder and is very hard, similar to an iPhone 2G.
Sostituzione batteria iPod Touch 3a generazione
Punteggio 0
Most likely it is the battery that needs to be replaced. If the ipod were damaged in some way then there could be a possibility that the logic board is damaged but the only way to tell would be to replace the battery.
Punteggio -1
Aggiungi la tua risposta
Eric hyde sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 139
