Salta al contenuto principale
The first generation RAV4, known as the XA10 series was constructed on a unique platform that shared Carina and Corolla elements. It launched in Japan in May 1994.
7 Domande Visualizza tutte
My rav4 died and won’t start
1999 rav4 It has good fuel pressure ,good spark but won’t start . It just died and won’t restart had a new timing belt 20,000 miles ago?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Well make sure it has good air also. Check your air cleaner to make sure it isn't clogged. You should check your compression to make sure that it is within spec. Also another thing to check is your crank angle sensor. Because if that thing is dead, it will crank for an eternity and never start.
Punteggio 0
Aggiungi la tua risposta
Jody sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,221
