How do I put shredder into alignment?
message on shredder says it is out of alignment. I tore it down to remove a paper jam put it back together and this message appeared. How do I get it BACK INTO ALIGNMENT?
Questa è una buona domanda?
Ottieni un rapido accesso alle guide, ai componenti e alle risposte per i tuoi dispositivi
Without knowing all the details, I can only suggest that you tear it down again. when you get to the blades, make sure the teeth are lined up alternately. I'm guessing when you pulled out the paper jam, it tweeked one/both of the blades. Make sure both blades are seated in the proper position.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 9
Tutti i Tempi: 870
whats the model number?
da Aiden
