Salta al contenuto principale
Angelcare AC401 baby movement & sound monitor produced since 1999.
Lcd screen doesn't display
Good day, I hope you might be able to assist me. I bought a second hand angel care movement and sound monitor but after I received the monitor I found that the parent unit doesn't display anything. I replaced the parent units batteries and charged it for hours. Yet no display, I did speak to angel care South Africa but they informed me that this model has been discontinued.. Is this device fixable? Or will I have to purchase a newer model?
Kind regards,
Adri Van Heusden
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @adrivh ,
Did you hold the monitor unit On/Off button for 2 seconds to turn it on?
If you haven't got one, here is a link to the User Guide for the Angel care AC401 baby monitor
Did the seller of the unit say that it was in a working condition?
If so, I suggest that you contact them about the problem or get a refund.
If it was sold, as is, with no further information provided then here is a link to the ifixit Smontaggio del baby monitor Angelcare AC401 guide.
It shows how to open the unit so that you can check for any obvious problems such as broken wires, dry joint connections, burnt out components etc. Use a DMM (digital multimeter) to check that the full battery supply is reaching the circuit board.
Punteggio 2
Parti e strumenti correlati
Aggiungi la tua risposta
Adri Van Heusden sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 8,622
