Salta al contenuto principale
The LG Stylo 3 Plus is an Android smartphone released in 2017 by T-Mobile. It features a 5.7-inch HD display, 32 GB of storage, and runs the Android 7 OS.
Help merging 2 incoming calls
Hi I have the lg stylo 3 I'm having trouble with the 3-way calling. When I try to merge the 3rd party the only option I'm given is swap calls. Im not given the merge calls option, help.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
From the phone dialing screen tap the menu (3 dots), and there should be an option "Add Call". Dial that number you want to add, or via contacts.
When the second call is established, there should be a "Merge Call" option.
Punteggio 2
4 Commenti:
Yes there is a merge option but when I click merge it say cannot merge calls and then it hangs up
da
OK, then its an issue with your phone. See if there is a software update to fix this.
check settings --> About phone --> Software update or
Settings --> software update, depending on the carrier.
If this doesn't resolve it, contact your carrier.
da
Any idea if there is no Add Call button in Dialer app (Phone is LG G6 U plus) Korean set ?
da
Try going into ncall setting and enable your confrence calls
da
Aggiungi la tua risposta
Tanya Bernal sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,877
