Salta al contenuto principale
Released on November 22, 2005, the Xbox 360 wireless controller is the primary game controller for the Microsoft's Xbox 360 home video game console.
x-box controller not connecting to console
on/off light flashes but dose not connect to console . was working earlier. changed batteries. did not help
Questa è una buona domanda?
Punteggio 0
1 Commento:
My controller is not sync with xbox 360 even I attempted alot to restart, sync button press for both controller and console but unable to find solution.please help even I refixed hard disk also
da
Aggiungi un commento
2 Risposte
You should manually pair the controller to the Xbox. Use this link to help you.
https://support.xbox.com/en-US/xbox-360/...
Punteggio 0
2 Commenti:
tried your link. did not work.. I have had my x-box 1 for about a yr. the controller was working earlier in the day, turned x-box off tried to turn it on a couple hrs. later. it did not turn on the console. I turned console manually than turned on controller. the on/off button just flashed. changed batteries. did not help.. stumped :(
da
Well I would just assume the controller is done in for and buy a new one. Microsoft doesnt say much about this.
da
Preparati per le riparazioni future
Acquista tutti
i am also having this problem. .with all 4 of my controllers..none of them will connect..fresh batteries nor resyncing did any good. .worked absolutely perfect last night
Punteggio 0
Aggiungi la tua risposta
mike sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 24
Tutti i Tempi: 3,662
