Salta al contenuto principale
Part of the Rebel Series, the Canon Rebel T4i is a Digital SLR with an 18 megapixel sensor with an LCD monitor. Also known as the EOS 650D and the EOS Kiss X6i.
Why isn't the image being saved?
I noticed some time back that the image is not saved onto the SD card in spite of everything sounding normal during taking the shot. This ws under normal daylight conditions in the A mode. It started with skipping the occasional image, then it stopped saving any images the next time I tried then I tried taking the shots on the M mode; now it isn't saving the images. This is in spite of the card showing plenty of space.
Questa è una buona domanda?
Punteggio 0
1 Commento
Thanks. Sounds logical. will try another memory card and took advice and reformatted card. It did seem to start Ok then went funny again. Memory card does seem to be the issue.issue
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Try another Memory Card. I would think your Memory card is on the way out.
Punteggio 3
2 Commenti:
Yes, reformat the memory card. If no joy try fresh one. All cameras tend to run into problems if the battery is diminished. Give it a full charge & see if it operates correctly. Battery & memory card are the first ports of call.
da
And if you can do it via the options, give it a sensor clean while you're at it.
da
Aggiungi la tua risposta
Karim Ibrahim sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 2,015
