Salta al contenuto principale
Rilasciato a Gennaio 2015, l'XPS 13 ambisce ad essere il rivale commerciale del MacBookAir, con lo schermo senza bordi e il Touch-screen opzionale.
Cannot remove the screw inside magnetic cover
I've tried to unscrew it for literally 5 minutes.
I'm sure it's loosened but it doesn't lift.
It's just stuck in the cover.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
it has no hard drive in it, give it a smack. alternatively, do the other screws and it should still come right off as the screws are not anchored.
Punteggio 0
1 Commento:
i've tried to smack it but feared that the hinge will be broken.
And what do you mean the second option? just pry it anyway since the middle one isn't anchored? It does feel stiff when i try to pry the edges.
da
Oops! I forgot to check if we have a guide, just follow this guide. Sostituzione copertura inferiore Dell XPS 13
Punteggio 0
3 Commenti:
this doesn't mention the middle screw...
i'm confused right now whether or not i should force it...
da
Hmmm... whats your model?
da
its xps13 - 9350
da
Aggiungi la tua risposta
No man Space sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 352
