Salta al contenuto principale
Suggerimenti e trucchi per un uso ottimale di iFixit.
4mm Bit extension options?
Hello,
My BF had gotten me the 54 Bit Driver Kit from Ifixit years back as a gift and I've lost count on how much money it's made me between my two jobs and my moonlighting, but I recently got into more miscellaneous electronic repair and scrapping and a lot of the stranger devices/appliances require a longer/thinner driver than the Ifixit one. Does anyone have any suggestions for a good, durable extender that doesn't add much thickness, or even a different longer driver that I can also carry with me?
Thanks,
Derek.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
6 Risposte
Soluzione Prescelta
See https://meta.ifixit.com/Answers/View/103...
I asked a similar question on iFixit Meta some months ago and came across you question in searching for it again. I was told my suggestion would be put to the Tools Dev Team but haven't heard anything since, which is a pity because I have a birthday coming up.
Punteggio 1
Parti e strumenti popolari
Risposta Più Utile
Wiha makes one called System 4 Magnetic Extension Blade for Micro Bits Part# 75901 its super narrow for getting into recessed screw cavities and can be stacked to reach even further. The only setback is its not very magnetic so you might have a hard time picking up larger screws.
Punteggio 2
2 Commenti:
Bradford, thanks for the recommendation. Picked up a couple of Wiha 75901's from Digi-Key, and has already proven useful for opening a game console. Good stuff.
da
where can I buy it
da
I bought a specific Torx set with about 5-6” shafts which eliminated the extender bulge. Many times ANY bulge will create a problem so I would look for what you need with the long shaft instead of an extender.
Punteggio 0
1 Commento:
Indeed, the ideal is to have the right screwdriver for every screw - fine if you're in your own workshop with plenty of space for storing a galaxy of tools but we're not always lucky enough to be able to enjoy that. Before the pandemic (and hopefully again in the coming months) I used to attend pop-up community repair events, often travelling by train and/or bus and sometimes up to a mile's walk, and with no idea what challenges I might face. Along with all the other tools, it's then necessary to maximise usefulness whilst minimise weight and bulk, and a driver and set of bits is then the only sensible option and an additional range of long screwdrivers is not an option.
da
Hi @pleriche ,
I also attend community repair events and I’m also looking for a solution.
The solution proposed by @cspanpacman seems reasonable but I'm afraid that the buldge would still cause problems, like @ruggb emphasized (at least for the skinniest bits).
How do you manage this problematic in the meantime of an optimized solution?
Personally I was lucky enough to always have a fellow repairer that comes with his huge tool case ready to lend me longer shafts. But I would be more confortable to have an skinny extender. In terms of production footprint (and cost for our wallet) a good extender would save lots of long shaft versions for each bit we could need…
Do you think a good extender would be impossible considering the (failed) attempt of iFixit’s tool development team? (https://meta.ifixit.com/Answers/View/103...)
In short for future folks coming here, according to you, what kind of conclusion could we make about this problem ?
Best regards,
Geoff
Punteggio 0
1 Commento:
Hi @geoff5 - I still don't have a real solution. I have a set of 50 75mm 1/4" bits that I usually take with me, but they add a fair bit to the weight and arn't always long enough. You would have thought it'd be possible to make an extender consisting of 6 pieces to grip the bit inside a thin but very high tensile band to hold them together. But what do I know?
da
Note that as of February 2022, the Wiha magnetic extension suggested by Bradford May 2021 has been reported by DigiKey as discontinued by the manufacturer.
Punteggio 0
2025, Found this on eBay for ~$13/14 USD. Worth it for me. Already found that I need it and the whatever-its-for wiggly useless extension just doesn't have any use for reaching recessed holes:
https://www.ebay.com/p/7012058762
Punteggio 0
Aggiungi la tua risposta
Derek sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 91
Tutti i Tempi: 3,218
