Salta al contenuto principale
The Motorola Xoom is an Android-based tablet computer by Motorola, introduced at CES 2011 on January 5, 2011. It is the first tablet to run Android 3.0 Honeycomb.
20 Domande Visualizza tutte
Wifi Only Xoom upgradable to 4G LTE?
Because this teardown is a 3G model that is upgradeable to 4G It obviously has the blank mini-PCI interconnect board and all the pin connections. If (hopefully) Motorola releases a WiFi only XOOM in the U.S. and they leave all of the pin connections in the device, would it be possible to do a 4G upgrade to your WiFi-only XOOM? Or will it not have any of the chips needed to take use of the LTE radio?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
9 Risposte
Risposta Più Utile
I just tore a WiFi only Xoom apart. There are blank solder pads on the circuit board where the necessary parts would go. In other words, it would be a major rework of the device to add those parts, it's not as simple as plugging in the mini PCI card. There are also no cellular antennae in the device. I would suggest there's too much missing to make it upgradeable.
Punteggio 1
1 Commento:
Wisdom from someone whose already been there is always good. Thank you, because I was wondering this myself.
da
I doubt verizon would design it so upgrading it is possible.
Punteggio 0
It will probably be possible to swap the "Interconnect Card" with a 4G LTE Module, however the software may be locked to not support it. I cannot verify whether you can or not (I don't own a Xoom) but the teardown makes it look like it may be possible.
Punteggio 0
I solderd the sockets from an old streak 7 and installed the antennae on to my wifi xoom, i tried a tmobile and a att card and it did not work, i was just looking at the tear down pics again and there are componentand on the MB that are not on my wifi MB, wish i would have look more closely before i did all that work
Punteggio 0
If they wanted Xoom to have LTE support, they would have included it from the very beginning. I don't think they would release any updated to fix this.
Punteggio 0
why not add an external 4G dongle? Then you could move it to other computers.
Punteggio 0
Wifi not working. Cannot connect to internet
Punteggio 0
Carry one of them 4G hotspot devices in you pocket. I had one from Clear networks. It handled eight devices and was about the size of a pack of smokes. The service was around fifty bucks a month/unlimited. Worked good for me and I did not have to pay twice as much for Verizon's 4G.
Punteggio 0
i have a xoom and know for a fact that there is no software to use cellular. it would need to be rooted and flashed with a new rom for the original xoom, this might get the software side working.
Punteggio 0
Aggiungi la tua risposta
cory dunbar sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 10,317
