Salta al contenuto principale
iFixit utilizza i cookie per migliorare le funzionalità del sito, analizzare il traffico e personalizzare gli annunci. Utilizzando il nostro sito, accetti l'uso dei cookie e l<link>Informativa sulla privacy</link>.
7.9 inch display / Model A1454 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
Digitizer Plug on Logic Board
Hi Guys,
I have an Apple iPad Mini 1st Gen Model# A1432 here which needed the Digitizer replaced. The plug that the Ribbon Cable clips into on the Logic Board is missing some of the Gold Pins and as a result the Digitizer isn't working. I am not sure what this item is actually called. I was just wanting to know if anyone could help with the of that part and or if it is available to purchase. I will also need to Purchase a new LCD Screen at the same time as when I turned it on it's coming up with 2 apple logo's and lines across the screen. Any help would be greatly appreciated. See picture attached the part I need is circled. Thank you in advance.
Regards,
George McMahon.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
You can buy those but you need someone proficient in micro soldering and previous experience of doing those really to attach it correctly.
Punteggio 0
2 Commenti:
*cough cough* @refectio *cough cough*
da
Thank you so much for your help. I really appreciate it. I will definitely have to look for someone who is proficient in Micro Soldering as I am not. Thanks again,
Regards,
George McMahon.
da
Parti & Attrezzi Popolari
Acquista tutti
Risposta Più Utile
@gm78 the connector is a Molex 503304-2010 . It is available at places like this and many others. To repair it you will need to know how to microsolder (and of course have the tools) or get someone like @refectio to repair it for you.
Punteggio 1
3 Commenti:
@oldturkey03 where do you find this stuff out? so much random knowledge! =)
da
@captainsnowball it's all random from fixing random things ;)
da
Thank you so much I really appreciate your help. I definitely am not proficient enough in micro soldering so will have to get it done by an expert. I am in Adelaide. South Australia. I will have a hunt around to see if I can find someone here that can do it if not I will look into @refectio to do it for me. I really appreciate your help. Thanks Again.
Regards,
George McMahon.
da
Aggiungi la tua risposta
George McMahon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 305
