Salta al contenuto principale
HDD Errors (UDMA CRC Errors)
Hi,
In the SMART Utility log file I noticed that my HHD had a high number of CRC Errors. I replaced the HDD with a new Hitachi Travelstart 500G HDD, and still got the same errors. I also replaced the HDD Cable: same result the errors still occur.
See SMART Utility log file below.
Could there be something wrong with my motherboard?
Am I at risk to loose data?
Regards
Erik.
SMART log file:
partition count: 1
partitions: Macintosh HD,
SMART Support: Supported
Last SMART Error: *not set*
Model Family: *not set*
Model: Hitachi HTS725050A9A364
Serial Number: 101128PCK404GLG2GU4J
Firmware Version: PC4OC70E
Capacity: 500,107,862,016 bytes
ATA Version: 8
ATA Standard: ATA-8-ACS revision 6
Health: Passed
Overall Health: PASSED
Offline Data Status: 0
Self Test Status: 0
Offline Data Collection Time: 645
Data Collection Capabilities: 5B
SMART Capabilities: 3
Error Logging Capabilities: 1
Short Self Test Time: 2
Long Self Test Time: 131
Conveyance Self Test Time: 0
Attribute Log Revision: 16
Attribute Count: 19
Attributes:
ID# ATTRIBUTE NAME FLAG VALUE WORST THRESH TYPE UPDATED FAILED RAW VALUE
1 Raw Read Error Rate 0x000B 100 100 062 Pre-fail Always Never 0
2 Throughput Performance 0x0005 100 100 040 Pre-fail Offline Never 0
3 Spin Up Time 0x0007 173 173 033 Pre-fail Always Never 2
4 Start/Stop Count 0x0012 100 100 000 Old age Always Never 136
5 Reallocated Sector Count 0x0033 100 100 005 Pre-fail Always Never 0
7 Seek Error Rate 0x000B 100 100 067 Pre-fail Always Never 0
8 Seek Time Performance 0x0005 100 100 040 Pre-fail Offline Never 0
9 Power On Hours 0x0012 100 100 000 Old age Always Never 75
10 Spin Retry Count 0x0013 100 100 060 Pre-fail Always Never 0
12 Power Cycle Count 0x0032 100 100 000 Old age Always Never 73
191 G-Sense Error Rate 0x000A 100 100 000 Old age Always Never 0
192 Power Off Retract Count 0x0032 100 100 000 Old age Always Never 1
193 Load Cycle Count 0x0012 099 099 000 Old age Always Never 13221
194 Temperature Celsius 0x0002 229 229 000 Old age Always Never 24 (Lifetime Min/Max 15/39)
196 Reallocated Event Count 0x0032 100 100 000 Old age Always Never 0
197 Current Pending Sector Count 0x0022 100 100 000 Old age Always Never 0
198 Offline Uncorrectable Sector Count 0x0008 100 100 000 Old age Offline Never 0
199 UDMA CRC Error Count 0x000A 200 200 000 Old age Always Never 143
223 Load Retry Count 0x000A 100 100 000 Old age Always Never 0
Error Log Version: 1
Error Count: 75
Error Log:
Error 75 occured at disk power-on lifetime: 75 hours
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
00 51 01 10 00 00 00
Error: Unknown
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
2F 00 01 10 00 00 00 00 00:13:12.500 READ LOG EXT
60 00 30 88 40 67 40 00 00:13:12.500 READ FPDMA QUEUED
60 E8 28 F0 D5 66 40 00 00:13:12.500 READ FPDMA QUEUED
60 10 20 E0 D5 66 40 00 00:13:12.500 READ FPDMA QUEUED
60 08 18 D8 D5 66 40 00 00:13:12.500 READ FPDMA QUEUED
Error 74 occured at disk power-on lifetime: 74 hours
Error: Unknown
2F 00 01 10 00 00 00 00 00:01:32.500 READ LOG EXT
60 B8 F8 68 1B 93 40 00 00:01:32.500 READ FPDMA QUEUED
60 00 F0 68 13 93 40 00 00:01:32.500 READ FPDMA QUEUED
60 00 E8 68 0B 93 40 00 00:01:32.500 READ FPDMA QUEUED
60 00 E0 68 03 93 40 00 00:01:32.400 READ FPDMA QUEUED
Error 73 occured at disk power-on lifetime: 70 hours
Error: Unknown
2F 00 01 10 00 00 00 00 00:37:53.600 READ LOG EXT
60 50 B8 08 55 54 40 00 00:37:53.500 READ FPDMA QUEUED
60 A8 B0 58 4F 54 40 00 00:37:53.500 READ FPDMA QUEUED
60 00 A8 58 47 54 40 00 00:37:53.500 READ FPDMA QUEUED
60 78 A0 E0 41 54 40 00 00:37:53.500 READ FPDMA QUEUED
Error 72 occured at disk power-on lifetime: 69 hours
Error: Unknown
2F 00 01 10 00 00 00 00 00:52:46.300 READ LOG EXT
60 00 30 A8 79 BD 40 00 00:52:46.200 READ FPDMA QUEUED
60 00 28 A8 77 BD 40 00 00:52:46.200 READ FPDMA QUEUED
60 00 20 A8 76 BD 40 00 00:52:46.200 READ FPDMA QUEUED
60 80 18 28 76 BD 40 00 00:52:46.200 READ FPDMA QUEUED
Error 71 occured at disk power-on lifetime: 68 hours
Error: Unknown
2F 00 01 10 00 00 00 00 00:36:21.200 READ LOG EXT
60 40 F0 28 B6 B0 40 00 00:36:21.200 READ FPDMA QUEUED
60 40 E8 E8 B5 B0 40 00 00:36:21.200 READ FPDMA QUEUED
60 40 E0 A8 B5 B0 40 00 00:36:21.200 READ FPDMA QUEUED
60 40 D8 68 14 B0 40 00 00:36:21.200 READ FPDMA QUEUED
Self Test Log Revision: 1
Self Test Log Count: 2
Self Test Log:
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
  1. 1 Extended offline Completed without error 0% 74 -
  2. 2 Short offline Completed without error 0% 11 -
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Soluzione Prescelta
A CRC error is a sign of a corrupt archive. CRC stands for "Cyclic Redundancy Check" and is a means of verifying the integrity of an archive. For RAR archives, if redundancy records were included, it is sometimes possible to work around the error. Most of the time, this error isn't really fixable except by trying again. Download the newest Stuffit and unzip the files in your user download folder.
Punteggio 3
1 Commento:
I HAD the same error with my Lenovo g580 ..I cant installing games or any setup ...i changed everything ......HDD AND RAM I want TO know if there is a problem with my motherboard or NVidia card??? cuz i cant play games or installing program
da
Preparati per le riparazioni future
Acquista tutti
Ultra DMA CRC error rate Low value of this attribute typically indicates that something is wrong with the connectors and/or cables. Disk-to-host transfers are protected by CRC error detection code when Ultra-DMA 66 or 100 is used. So if the data gets garbled between the disk and the host machine, the receiving controller senses this and the retransmission is initiated. Such a situation is called "UDMA CRC error". Once the problem is rectified (typically by replacing a cable), the attribute value returns to the normal levels pretty quick.
Punteggio 2
2 Commenti:
Did your solution fix the problem?
da
What do you think, is that possible that old battery cause thus problem too ? is there some utility to check how do the connectors or cable works?
da
I would suggest you to try utility below
winrar fix
it can also restores huge .rar archives over 2GB and solve .crc errors out
Punteggio 0
LOL @ Mayer, read the question better. This has nothing to do with RAR files, CRC have many applications, not just in archives
Punteggio 0
Aggiungi la tua risposta
Erik253 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 6,722
