Salta al contenuto principale
Il Samsung Galaxy Note 4 è uno smartphone rilasciato nell'ottobre del 2014. Il numero di modello del Galaxy Note 4 è SM-N910, SM-N910A, SM-N910T, SM-N910V o SM-N910R4 per le varianti americane.
Note 4 No Sign of Life
I've been trying to get this Galaxy Note 4 working, and it is showing no signs of life. When it is plugged in, the notification light does not show. I have tried every combination of buttons I've heard, and it won't do anything. It doesn't vibrate, the notification light does not turn on, and the screen does not turn on.
I tested for voltage on the battery terminals with the battery out and the charger connected, and it shows 4.19 volts.
I have replaced the battery with a known working battery, and it did not act any differently.
I'm pretty certain at this point that it's a hardware issue, but what can I check? Being that I'm getting voltage at the battery, I know the charging port is working properly. The only other thing I can think of is something on the motherboard is bad, but of course if anyone has any idea, I'd love to hear them!
Updated with pictures...
Immagine
Immagine
I just removed the motherboard for simplicity in the picture.
Tested the battery again... It is showing 3.79V. Still no sign of life. Where is PWR7000? And the other things, for that matter.
Update 2: I removed the cover, everything looks to be alright. The scratch on it is just from a screwdriver... my mistake!
Immagine
Questa è una buona domanda?
Punteggio 2
2 Commenti
PWR7000 is your power switch
da Condividi
I got that, I was just trying to see where the power switch leads in order to check for obvious damage.
Post updated again.
da Condividi
Aggiungi un commento
1 Risposta
Risposta più utile
@boostedmoose115 follow the troubleshooting flowchart
Immagine
Immagine
If you need to find the components etc. post a couple of images of your motherboard. Use this guide Aggiungere immagini ad una domanda for that
Update (01/20/2018)
for U7000 and most of the components you'll have to remove the EMI shield as pointed out
Immagine
Punteggio 2
6 Commenti:
Chances are power management of needs to be replaced.
da Condividi
Thank you for posting, I'll double check the battery voltage and go over the rest of the flow chart at some point today and report back.
da Condividi
Updated.....
da Condividi
Would the V_BAT voltage be the battery voltage? And what is C7128, and how do I check it? I apologize for all the questions, but I can't find anything telling me what these things are. The the wiring diagrams either don't say anything or it's just impossible to see what they say.
da Condividi
I personally don't think note 4s are worth repairing for power ic issues. Too easy to crack the screen on open and already tried replacing multiple chips with no success.
Their prone to going bad on this model again anyway.
da Condividi
Mostra 1 altri commenti
Aggiungi la tua risposta
Alex sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 21
Tutti i Tempi: 6,204
