Salta al contenuto principale
The HP Pavilion dv9000 series was introduced in 2006.
Why does it shut down when touching the touch pad?
My laptop works fine until i put my hands on the touchpad then, its shuts off and reboot itself.
Questa è una buona domanda?
Punteggio -1
1 Commento
i can't use my laptop anymore:-(
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Can you attach a USB mouse and disable the touchpad and see if it works as it should without the touchpad
1. Click Start , Control Panel . Select Classic View from the left side of the Control Panel window.
2. Double-click Mouse in Control Panel, and then select Disable .
3. Click Apply , OK .
Also try to remove your battery which is housed underneath it I believe and see if you have the same problems w/out the battery, just run it on AC.
Punteggio 1
Preparati per le riparazioni future
Aggiungi la tua risposta
dijae10 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,818
