Salta al contenuto principale
The Epson WF-2540 is an all-in-one color inkjet printer. It features a 2.5-inch LCD touchscreen and four individual ink cartridges.
How to print test page on wf 2530
Howdo I print a test page on wf 2530? Should be similar to Epson WF 2540 but you don't have that printer listed.
Questa è una buona domanda?
Punteggio 5
Aggiungi un commento
1 Risposta
Risposta Più Utile
On Windows
• Open Control Panel
• Devices and Printers (Change view to small icons to see this)
• right click the printer
• go to printer properties
• click print test page
On Mac
• Settings --> Printers and Scanners
• Select your Printer
• Click 'Open Printer Queue'
• at the top you have new menus on the Finder bar for your printer such as 'edit', 'printer', 'jobs', etc.
Select 'Printer', and choose 'Print Test Page'.
Punteggio 3
4 Commenti:
Thanks for answering. This gives a Windows Printer Test Page, using black and cyan only. Is there a way to get one by going through the printer itself? If not, is there a way to go through Windows to test all colors?
da
Both methods above test all colors. The Windows Logo should utilize all color cartridges.
You can also test print by simply making a color copy of something.
da
The difference between an Epson and HP is the formulation of the Ink. HP is water based ink. When it rains, the documents printed will run. An Epson will not. Unfortunately, this is also creates a weakness for the Epson. Simple cleaning sometimes does not work. The ink may dry and clog the pipes and print heads. You may need to try to clean the printer with Alcohol or Ammonia.
da
Here's a test page that should test it well:
https://www.ifixit.com/Document/WvEk3HK6KyItKISD/.pdf
Ammonia causes more problems on Epsons; it damages the anti clog coating and encourages the problem more then it did before. Alcohol+water is the best option.
da
Preparati per le riparazioni future
Aggiungi la tua risposta
tennwanderer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 23
Tutti i Tempi: 7,030
