Salta al contenuto principale
Informazioni su riparazione e supporto della linea di laptop HP pensata per un uso home e home office.
Change HD to SSD and upgrade RAM
Hello,
I have HP x360 13-s102TU touchscreen laptop. Currently it has 1TB hdd and 4 GB RAM. I wanted to check whether it is feasible to change the HDD to SSD and upgrade the RAM to 8 GB.
I was checking over internet, but havent found any substantial support in this regards.
Else, the only option remaining is to open the laptop and check.
Hoping for a solution on this.
Regards,
Rohan
Questa è una buona domanda?
Punteggio 0
1 Commento
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Max RAM 8 GB 1x1 PC3 12800
Looks like you are good to go for under $200
Punteggio 3
4 Commenti:
Thank you @j0vian for the quick help. Can you tell me whether there will be a remarkable improvement in the system performance after this change in terms of using lightroom and photoshop?
da
There should indeed be a remarkable improvement.
da
Considering OP has a 5400 rpm HDD an SSD should be an extreme improvement.
da
@rohankonge If satisfied with the answer please choose the answer as the chosen solution so the problem will be marked solved. Thanks
da
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
Rohandeep Konge sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 723
