Salta al contenuto principale
Guide di riparazione e supporto per tutti i ventilatori meccanici domestici, inclusi ventilatori da soffitto, box, a torre e con il piedistallo.
Omega Altise Tower Fan Squeaks loudly when oscillating
Fan squeaks loudly when oscillating. I have tried taking the back off the fan (to see if it might look similar inside to previous response on squeaking fan). However could only find 4 screws and it does not seem to want to separate from the front of the fan easily. I am not sure if the cap on the top of the fan needs to come off first (cannot see any screws). I have tried vacuuming through the fan grill in case dust was the issue - this did not make any difference. Can you advise how someone without any technical expertise might be able to stop the fan squeaking please?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
You have probably sorted it now, but there will be retaining clips you need to gently squeeze the rear casing and it will come off, Then spay the moving parts with WD40 or the like and it should solve the problem.
Punteggio 0
Aggiungi la tua risposta
Elisabeth sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 708
