Salta al contenuto principale
Repair manuals for HP's "Mini" series of small form factor netbook computers.
Cracked Display Replacement Procedure...Tips?
My son inadvertantly cracked his netbook screen/display and we intend to replace the broken screen with a new one that will arrive in the next day or two. Anyone have tips for the most expedient way of detaching the screen bezel and opening the keyboard for access to the plug-in and such? A step-by-step would be very much appreciated if anyone has done this with their own HP netbook. Thanks a million.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Dave, there are so many laptops, and netbooks etc. that it becomes tough to keep it all in mind. That is why I try to always get a service manual before I get going on things :-) Anyhow I do have the one for your HP110 and I made it available to you for download at http://www.keepandshare.com/doc/2617573/... Can't get any more step by step than the manual. So if you download it you will have all the information needed for your task. Good Luck and let us know how it went.
Punteggio 3
Preparati per le riparazioni future
You order new replacement screen online by checking of desired model. Once your recive the replacement screen then you can follow the online tutorials to follow the instructions if you are confident about your technical skills. Otherwise take it to hardware shop and get if fixed from there.
Punteggio 0
Aggiungi la tua risposta
Dave sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 908
