Salta al contenuto principale
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
Boot problems after changing combo drive?
Hi
I have an A1181 Mac Book Duo 1.83 ghz with 1gb Ram. After I replaced the Combodrive when I turned it on the Apple logo appears and the starting sound, then keeps the starting sound appearing like an broken cd and it don´t boot any further. This problem didn´t appear always, sometimes it boot normaly and sometimes you couldn´t turned it on for days. So I open it up again did all the steps for changing the combo drive and after I finished when I turn it on, the screen goes white without the apple logo and the starting sound appears, then it will take 3-4 minutes till Apple logo appears and it boot normal. I can not tell if it starts now always like this because i just opened it yesterday but I wonder if the problem is that something is touching the logic board?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Go under the Apple in the upper left hand corner to system preferences -> system -> start up disk and select your hard drive
Punteggio 2
3 Commenti:
Still takes a minute, but it works Thanks
da
You're welcome. Did it take a minute to start before the drive change?
da
It varies from 1 to 3 minutes actually it didn`t change at all it seems to be a correlation between the temperature of the macbook and the time it takes to start to boot.
da
Aggiungi la tua risposta
Mario sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 644
