Salta al contenuto principale
The Philips Norelco Shaver 3100 is an all-in-one styling trimmer. It has multiple attachments for all your grooming needs. It is identified by model number QG3330/60.
7 Domande Visualizza tutte
Can I get a replacement for the standard blade/razor?
My Norelco Multigroom still working great, but I have problem with the main, wide blades on this model.
The blade wont stay in it's location. Usually you'd insert and turn and the head is locked in. My blade doesn't "lock in" and when this is turned on, the blade eventually is shaken loose and then won't work.
The smaller blades stay locked in with no problem, so it appears the problem isn't the main section.
I've looked online but can't find anything about obtaining a new blade.
Questa è una buona domanda?
Punteggio 0
1 Commento
Where can i get the blade i live in ocala fla
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Philips does sell accessories for this.
https://www.usa.philips.com/c-p/QG3330_4...
Is that what you are looking for?
Punteggio 1
1 Commento:
very close, but no cigar. Thank you! I looked around that site and the trimmer I need is wider that the one displayed. I do have the 3300 model, but when I looked around the site and it does not appear that the main/wider trimmer I need isn't there.
da
Aggiungi la tua risposta
phillyfrog sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 933
