Salta al contenuto principale
A Nokia E-series smartphone with a physical QWERTY keyboard and Optical Navi Key. Successor to the E71. Released in 2009.
Question regarding possible Camera replacement/upgrade
Will a Nokia E72 replacement camera part work in the Nokia E71 motherboard? In other words, can one upgrade the Nokia E71’s 3.2 MP camera to 5.0 MP using a spare part made for an E72?
Since the phones are very much alike (same size, same battery, etc.) I should think a simple swap should be possible, as long as the physical size and connector of the replacement part matches the original.
Thanks for your help.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Simply put, no. Not in hardware nor in firmware is it compatible.
Punteggio 1
1 Commento:
Thank you for your response. I was hoping it could be a simple swap of cameras.
da
Preparati per le riparazioni future
Aggiungi la tua risposta
Gam sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 9
Tutti i Tempi: 145
