Salta al contenuto principale
Third generation of iPad, featuring 4G capabilities, released on March 16, 2012. Model number A1430. Repairs require heat and careful prying.
Change to lightning port?
I have a 3rd generation ipad (Wifi + Cellular). I would like to know if it's possible to tear it down and install the components into a iPad 4 case and modify my components for the lightning connector?
Thanks
Matt
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
No, the flex for these two connector types are different and would not work properly from one logic board to another. While they look similar, minus the different form factor for the actual dock, they are completely different electrically.
iPad 3 Dock
iPad 4 Dock
Immagine Fix problems with USB data connections and charging problems by replacing a damaged, dirty, or corroded dock connector and its cable assembly in an iPad 3.
Prodotto
iPad 3 Dock Connector
$19.99
Immagine Replace a lightning connector compatible with the 4th Generation iPad Retina model A1458, A1459, and A1460. Fix problems with charging and data transfer.
Prodotto
iPad 4 Lightning Connector
$19.99
Punteggio 1
Aggiungi la tua risposta
Matt White sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 101
