Salta al contenuto principale
Soldering to USB +5V
So i have that Ali express LED Lamp projector, it has in build speakers and a LCD image unit that displays in 800x600. I thought i would be nice to upgrade it with a raspberry pi 0 that i got for birthsday. Just to play around with emulators.
I want the Pi to sit inside the projector, there is even some room left for it, i would take the HDMI cable outside just like this guy did:
https://www.youtube.com/watch?v=mff-F39f...
And use the 5V pin of the USB (inside the projector) port to the PI
My simple question is:
Will the USB port from the projector still work (for USB sticks) when the raspberry is powered by it?
Questa è una buona domanda?
Punteggio 1
1 Commento
Thank you!
Didn't thought about the heat. And there's really not much free space left for proper ventilation with the Pi inside.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
I wouldn't use it. The RPi 0 requires a minimum of 2.0Ah. It's had to imagine that the projector outputs more than 500mah. It'd probably run, but not very well. And certainly not when a USB flash drive is in use. You should use a separate power supply.
Last thing, if the projector is even slightly hot it will probably overheat the RPi.
Hope this helps!
Punteggio 3
Parti e strumenti correlati
Aggiungi la tua risposta
Prokrastinator sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 97
