Salta al contenuto principale
The ProHeat 2X is a carpet cleaner line made by Bissell Homecare, Inc.
How to fix the problem
Well not spray it's filled with water the Is on everything secure the reheater light is on but still would not spray water out
Questa è una buona domanda?
Punteggio 0
1 Commento
Can you share more information? What have you tried so far?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Do you distilled water or tap? If tap you may have a lime issue.
You'll likely need to soak the head & boiler in 'Lime Away' or other de-mineral solution.
Punteggio 1
Aggiungi la tua risposta
Nay sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 228
