Salta al contenuto principale
The tenth generation Corolla (E140/E150) was released in Japan in October 2006. A narrow variant was available in Japan while wider versions were sold internationally.
Repairing Air Injection valve (Error Code P2440)
I have a Toyota Corolla XRS 2006 Which has around 180 000kms on it. The engine light turned on so I took it to a mechanic and he told me that the error code was P2440 which was for the air injection valves near the motor. I looked around the internet and saw that there were ways to fix it but not a detailed enough one for me to follow. I have mechanical experience but I would like to try and fix it.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I don't have any mechanical guidance for you, but I did a bit of googling.
Here's how to clean that valve:
And this is a diagnostic for a similar, P0505 error.
Also try poking around for solutions to P2441.
The only difference between P2441 and P2440 is that in the P2440 the SVS is stuck open instead of closed.
Punteggio 2
Aggiungi la tua risposta
Ickaron sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 22
Tutti i Tempi: 3,445
