Salta al contenuto principale
Un discendente dello smartphone LG V10, simile all'LG G5, rilasciato il 29 settembre 2016. L'LG V20 si distingue per i numeri modello F800, H910, H918, H990 DS Dual, H990N Dual, H990 T, LS 997, US 996 e VS995. È disponibile con finitura titanio, rosa o argento con 32 o 64 GB di memoria interna.
Date and Time on Sleep Mode
My battery seems to be draining pretty fast. Doing whatever I can to remedy it. My question is, I just bought this V20 Unlocked and when it is in sleep mode, it constantly displays the time and date at the time, it's very dim but you can still see it.
Can this be removed or is this time and date on the sleep mode built into the phone where you can not disable it. Please help.
Thank you
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
You'll want to disable ambient display. Go to settings, display, then switch off ambient display. That should cut it! Also look at battery usage in settings and report your battery usage data.
Hope this helps!
Punteggio 1
1 Commento:
I went to setting then display and I don't see ambient display
da
Parti e strumenti correlati
Acquista tutti
Step 1: Settings
Step 2: Quick Cover Case
Step 3: Second Screen Settings
Step 4: When Main Screen is Off
Step 5: Toggle the “When Main Screen is Off" from On to Off
Punteggio 0
Aggiungi la tua risposta
Ron Gacek sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 719
