Salta al contenuto principale
"Il notebook da 15,6" più piccolo al mondo offre prestazioni elevate e uno straordinario display InfinityEdge, il tutto nel notebook XPS più potente di Dell."
How do I replace the audio jack?
My audio jack is faulty. Can't afford a new motherboard. Where can I find a replacement audio port?
Questa è una buona domanda?
Punteggio 1
2 Commenti:
Actually, the XPS15 9550 is barely or under a year old. Dell should replace it for free. IF not, check the credit card you purchased with, and they may cover the warranty for an extra year.
da
It has a broken headphone jack stuck in it. Dell said it won't be covered under the warranty period as its negligence/damage.
da
Aggiungi un commento
1 Risposta
The audio connector is part of the mother board. Unfortunately, Dell has decided that this problem is not warrantable. You may be in luck if the problem is a broken off part of a head phone jack and not a broken connection on the mother board. You may be able to remove the boken head phone part by using tweezers or use a paper clip bent into a small hook to pull the broken part out. You may be able to find a computer repair shop that can do this for you. Worst case is you may need to use a USB type audio head phone. Good luck
Punteggio 0
Aggiungi la tua risposta
Ketan Krishna sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 16
Tutti i Tempi: 1,662
