Salta al contenuto principale
iFixit utilizza i cookie per migliorare le funzionalità del sito, analizzare il traffico e personalizzare gli annunci. Utilizzando il nostro sito, accetti l'uso dei cookie e l<link>Informativa sulla privacy</link>.
The iRobot Roomba 770 is a cordless, autonomous vacuum that will clean your floor without supervision.
Blue light flashing on robot
There is a blue light flashing on the machine and it is making a thumping sound
Questa è una buona domanda?
Punteggio 1
2 Commenti
My blue flashing light looks like a magnifying glass, what is that for.
da
I have a flashing blue light but the indicator looks like a small circle with a few emitting beams, also the side brush is not moving at all.
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
@baldly Roomba 700 and 800: When in Dirt Detect mode, the blue Dirt Detect indicator will flash. You did not tell us which light. The dirt detect is the magnifying light. Make sure that you check the brushes and clean them well. If there is debris stuck on those they may trigger the dirt-detector sensor and you get your blue light flashing.
Punteggio 6
2 Commenti:
I keep my roomba pretty clean. I cleaned thoroughly and it worked for a few minutes. Then it went back to blue light and thumping noise. Any more suggestions?
da
I have exactly the same problem
da
Parti & Attrezzi Popolari
I had a blue star flashing and a thumping sound. I have the 770 model, so I went to the Roomba site and found this video: https://homesupport.irobot.com/app/answe...
It was simply a matter of cleaning the front wheel (I did not know it came out to clean it) and cleaning the brush and roller (I actually replaced them since I had spare parts on hand).
Punteggio 3
2 Commenti:
Blue star flashing after replacing filter roller and cleaner? what does that mean it's not the magnifier it's just a blue star I've never seen it before?
da
bingo! I've had this one for EVER and it has never done the bumpity thump blue star flashing before. I always pull the front wheel out and clean but have never pulled the plastic insert it slides into out. I had a big wad of fuzz under it. cleaned it out and VOILÀ, back in biz.
THANK YOU
da
Blue star like light is indicating problem with brush movement.
I found dirt under the silicon cover that prevent the brushes from turning.
Punteggio 0
Aggiungi la tua risposta
Jack Luhring sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 54
Tutti i Tempi: 45,366
