Salta al contenuto principale
Nel 2012, Sony annunciò che la società avrebbe rilasciato una nuova versione della sua console PlayStation 3 del 2006. La nuova console fu chiamata PlayStation 3 Super Slim ed è identificata dal numero di modello CECH-4000. La PlayStation 3 Super Slim (CECH400x) è la terza versione della console per videogiochi PS3 prodotta da Sony Computer Entertainment. Fu lanciata sul mercato il 25 Ottobre 2012.
Why is my HDMI output not working?
My PS3 slim was running as if it was superior to PS4 (that was a hyperbole). Once suddenly the HDMI output stopped working after 2 months of not playing. Then, I changed to an SD for some time and then got a new HDMI cable. It worked.
After almost a year of well working, Suddenly the HDMI output stopped working when I was playing Minecraft. I tried using a new cable, but this time it didn't work.
I searched a lot of IFIXIT forums and all around google. Everyone said,"hold the power button till the second beep." A guy also said that you should handshake,i.e. reset the video setting for a million times around (a hyperbole). I did try all of these but the problem didn't get resolved. SD output's rendering is very poor on my TV that if I see 10 building in HDMI assassin's creed 1, I see only 3 in SD.
How do I fix it?
Should I consider visiting a Sony centre?
Questa è una buona domanda?
Punteggio 9
7 Commenti
I have the same problem too!!! Except that I just woke up and tried to use the cord. My High Definition Multimedia Interface cord won't work! I even tried switching slots!!!
da
My PS3 was dropped down now it's no longer showing on any output. No dry joints or cracks on the board. Please help
da
what do you mean dropped down? You're best idea is first start your own question not comment on someone else's
da
My new PS3 (I replaced coz this problem wasnt fixed) Is showing the same problems. Please Help.
da
Am having the same problem but when connect using the avs it works just fine but the hdmi port doesn't display anything. Ps help
da
Mostra altri 2 commenti
Aggiungi un commento
8 Risposte
Soluzione Prescelta
the only solution is buying a new one. I got a new one. Thanks to y’all who tried helping tho.
Punteggio 2
1 Commento:
bro just but a PS2 to HDMI adapter its cheaper than a whole new PS3 you can get 1080p on AV using it Its the only way besides buying a new onee
da
Risposta Più Utile
I just had the same problem you had, and the solution i found is this.
Step 1: Unplug the PS3 power cable from the back of the console
Step 2: Make sure the only cable currently plugged in to your PS3 is the HDMI cable
Step 3: Unplug your TV power cord from the TV if possible, if not just unplug it from the wall
Step 4: Unplug any splitters from their power sources as well
Step 5: Leave your TV, PS3 and other devices unplugged for 30 minutes or so
Step 6: Plug back in your TV power supply and turn it on
Step 7: Plug back in any splitters you have
Step 8: Plug back in your PS3 power supply, and make sure the TV is set to the proper input channel
Step 9: Turn on your PS3 it should now work.
Punteggio 4
7 Commenti:
Your method was well organized, I didn't try it yet because I don't use my PS3 during weekdays. Only thing is that what are splitters and do you have any alternative method that I can use of this didn't work,because almost all the methods I came across till now we're useless. Lucky if this works!
da
The splitter i mentioned is this http://www.bestbuy.com/site/rocketfish-4....
I do not have an alternative method of fixing this, I was having the same problem you have been having, with every solution not working. Then I found this solution and it worked for me.
da
Oh thank you, I'll better try this method before asking further questions.
da
Thanks it works,You did a awesome job.
da
My new PS3 is now showing the same problems. I changed PS3 bcoz I cudnt fix it with the above answer. It's happening again, U have anymore suggestions pls?
da
Replace the HDMI chip
Punteggio 3
1 Commento:
Sony Centres dont do this for us anymore.
da
Your IC ( HDMI) Is overheated and you need to change the hdmi
Punteggio 2
3 Commenti:
Doesn't help really. No Offense. I'm sure anyone asking a question in iFixit would've checked things like this before hand
da
@rishirockzz how would you check if your ic chip was overheated? I think this kind of comment helps alot whne everyone else is saying do a video reset.
da
My apologies, "IC(HDMI)" was slightly misleading and I thought they were talking about the HDMI cable which also has an alias "IC".
da
Yes same thing happens when I do it none of those work it looks like a corrupted data
Punteggio 1
Sometimes your HDMI cable is just broken. the only answer is to get a new ps3 and transfer the data via ethernet cable
Punteggio 1
Same here, my ps3 can’t connect to my led tv with hdmi. But when i connect to my ps3 hdmi to vga monitor(using vga to hdmi) and it works. Any solution how can i play again on my led tv? :(
Punteggio 0
1 Commento:
That's interesting... ps3 hdmi is so weird
da
Someone can help me? My ps3 over a 2 week it does not work HDMI but turn on red and green light
Punteggio 0
Aggiungi la tua risposta
RishiNandhaVanchi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 125
Tutti i Tempi: 47,858
