Salta al contenuto principale
Versione migliorata del Nintendo Game Boy Advance, l'Advance SP è stato rilasciato il 23 marzo 2004 in Nord America, con una struttura quadrata ed un design a conchiglia.
How can I properly re-insert the hinges?
My GBA SP can flip open, staying about 150 degrees. After I got a new shell, the screen part began to feel more heavy (loose and floppy to say the most) and doesn't make that *click* sound whenever I open or close my gameboy. I figured it would be the hinges so I reopened my handheld and disassembled most of the parts to get to them. I fixed the hinges, but the screen half still flops; bypassing the 150 degree angle to 180 and still doesn't do the clicking. I've done this numbers of times fixing them with no luck. I don't understand where the problem lies whether I improperly repositioned the hinges or that they were very worn conditioned. :\
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I never dissassembled one, but, you can try to rotate the hinges (if you can) 180 degrees, maybe is an issue of just tightening the screws a little more. Also could be the new shell, specially if its a cheapo one, are poor quality build, and most of the time will wobble and cause the problem, or if it's used, could be broken as well...
Punteggio 0
Aggiungi la tua risposta
braxtongsp1 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 18
Tutti i Tempi: 3,091
