Salta al contenuto principale
Smaller version of the original iPad Pro. Released March 31, 2016. Features a 9.7" display, A9X processor, and 32/128/256 GB storage options. Available in Silver, Space Grey, Gold, and Rose Gold.
I need help with a Digitizer/Glass replacement (LCD is okay)!
Hello guys! So, I got an iPad Pro 9.7 and after an accident the glass is shattered but the LCD behind it is all right. The touch functions also work perfectly, even in the sections where the glass is broken.
So, I went ahead and bought a Digitizer/Glass advertised as coming "with tape replacement" (forgive me if I am mistaken, but I think Digitizer/Glass refer to the same component, at least in this case?). Here it is:
"New Assembly For iPad Pro 9.7" LCD Display Touch Screen Digitizer Lens Glass With Tape Replacement"
So, I have been watching videos and for this specific iPad I only seem to find guides and videos of people replacing the whole thing (LCD + Digitizer). In my case I only want to replace the digitizer. In some videos such as this one (iPad Air 2) there seems to be a glue (OCA) holding the LCD and the digitizer together (and a bunch of specialized equipment involved) but for other iPad models there appears to be no glue and appears to be much easier to do such as here. So.... 2 questions my friends:
1- Any of you have experience with the pro 9.7? will there be glue similar to the iPad Air 2? any tips or any other video that you can suggest of another iPad model that is the most similar to mine?
2- What tools would you recommend? I am thinking about purchasing this:
A) iOpener kit: iOpener
or the Essential Electronics toolkit: Essential Electronics Toolkit
Which kit do you recommend?
and B) Some tape:
red [prodotto collegato mancante o disabilitato: IF317-071-2]
polyimide: Polyimide Tape
61395: Tesa 61395 Tape
Which tape do you recommend?
And last but not least... what other tools would you suggest? I already have a heat gun, but if you can think of anything else please let me know.
Thank you so much for any help that you can provide me with!!
Cheers!
Immagine 108 foot rolls of Polyimide tape. Perfect match with OEM Apple Part# 922-1731 tape. Half-inch (.5") width.
Prodotto
Polyimide Tape
$9.99
Immagine No more adhesive battles! With our iOpener, you can quickly and easily remove glued components in electronic devices whether you're a repair professional or beginner. Apply gentle, even heat to loosen the adhesive holding smartphone, tablet, and laptop case components and batteries.
Prodotto
iOpener
$19.99
Immagine Our gateway kit to electronics repair, perfectly sized and priced for essential electronics repair.
Prodotto
$29.95
Immagine Custom cut rolls of Tesa 61395 double-sided tape for repair.
Prodotto
Tesa 61395 Tape
$5.99
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
On the iPad Air 2 and Pro models, the LCD and Digitizer are fused together, similar to the iPhones. You can't really replace just the digitizer unless you get all into "refurbishing". Frankly, given the size of the iPad screens, it would be extremely difficult to do a professional job with LOCA and doing it with OCA requires professional grade machines. Not to mention all of the consumables required...
So in a sense, you got "had" by whoever sold you this. The only way to fix a broken iPad Pro screen is to buy the complete assembly.
As for tools and videos, the iPad Pro 9.7 repair is similar to the iPad Air 2 but here are some videos you can look at.
Immagine Replace a LCD Screen and digitizer compatible with the A1673 and A1674 model iPad Pro 9.7". 2048 x 1536 (264 ppi).
Prodotto
iPad Pro 9.7" Screen
$179.99
Punteggio 4
Parti e strumenti correlati
Acquista tutti
Aggiungi la tua risposta
Daniel Vargas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 29
Tutti i Tempi: 4,938
