Salta al contenuto principale
Controller LED per la Playstation 3 prodotto da Performance Designed Products, LLC con modello Numero 064-015-EU-BL.
USB Not connecting to PS3
My PS3 afterglow controller has always worked great but recently the USB drive just stopped connecting. Now whenever I plug in the USB to my system it just continuously blinks. My USB ports are working fine because I can still charge other controllers and the actual USB to the controller connects perfectly fine to my PC just not my PS3. So I have no clue what the issue is and I don't quite want to get a new controller yet because it seems like this one still works, it just isn't connecting to my PS3 right now. It'll be great if someone could answer this
Questa è una buona domanda?
Punteggio 3
1 Commento
how u dont use the usb for ps3 and pc
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Check the pins on the controller's end of the USB. Are any of them bent or dirty? A short due to a bent pin or dirt blocking a connection could be causing the issue. It also would not hurt to give the controller's usb pins a cleaning with contact cleaner to ensure a clean connection. I would also recommend checking the cable itself, to see if their are any kinks in or exposed wiring. If that doesn't it fix it, then its most likely a problem within the controller's PCB board.
Punteggio 1
1 Commento:
What is a pcb board and how can i fix it or clean it so i can get the controllers to work
da
Preparati per le riparazioni future
Aggiungi la tua risposta
Ty Smothers sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 19
Tutti i Tempi: 12,193
