Salta al contenuto principale
Modello A1224 dal metà del 2007 all'inizio del 2008 / processori Core 2 Duo a 2, 2.4 o 2.66 GHz
Cannot Find Appropriate SSD Mounting Bracket
Hi. I'm trying to replace my hard drive with an SSD. The disassembly went great, but I got stuck when my mounting bracket wasn't long enough to use the iMac mounting system (it didn't have all three holes on each side). So I bought another one, and it didn't have threaded holes for the iMac mounting system. Then I bought a third one, and it works perfectly with the mounting system EXCEPT that there isn't enough length on the data cable. It just wont reach. The cable is just long enough to fit a regular drive. I don't know what to do. Please help.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I'm answering my own question. The data cable goes underneath the logic board and comes around the bottom of the computer, just above the RAM modules. There was a tiny bit of slack in the cable, so I gently loosened it and pulled up the slack. Perfect fit. I hope this helps someone else.
Punteggio 0
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
bjelliott sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 115
